Default saving folder
Jet47
Automotive
CA
How can I set a default folder when I use the funcion SaveAs in Catia V5.
Currently, the default folder is set to MyDocuments folder but I want to customise it without using the DLLName.
Launch the environment editor and set the "USER_HOME" variable into your favorite path.
Best regards
Also it is a good idea to set your Search Order this will default what folders open up when you select File Open if nothing has been read previously.
