nytimes123
Materials
I am looking for a cheap material to replace deep drawn steel sheet in a product. Steel sheet is coated with ceramic coating and used in high temperature applicatioins. I have tried ceramic cloth ( metal reinforced and moulded in different shapes with the help of fiberglass). It works almost same as ceramic coated steel sheet but dimensional tolerances are not precise.
Is there any other material with same characteristics (high melting point 1300C, mouldable in different shapes)which i could use?
