Dearch and open a drawing 1
gelengman
GB
Is there a way to create an AutoLisp program that will search through folders for a given drawing file.
The findfile function will confirm whether a file exists in a given folder, but I would like to search through a number of folders without explicitly stating which folder(s) to look in.
Do I have to use VBA instead?
I am presently using AutoCAD 2000
OK, so I have made a typo on the subject!
Should read Search and Open a drawing
In AutoCad, click "File" and "Open". Then, click "Tools" and "Find". Autocad can search your drive(s) for a file, like Windows explorer.
Your right of course and maybe I'm looking for some sort of Utopia, but what I would like to do is press an icon, type in a drawing number and have the file located + loaded - Useful if you want a drawing while on the phone etc..
Of course, I would have to have some sort of check that there was not two drawings of the same filename.
I have written a lisp in the past that looked in a pre-set list of folders, however I now work in a project based environment with ever-changing folders.
Any thoughts?
Thanks - I'm in a new direction
