Dear All, Wants to verify the fina
Nitin Khollamkar
IN
Dear All,
Wants to verify the final pressure at the wash basin inlet point for a G+3 building height of 25m through CPVC down take pipe with a reduction from 10m 32mm dia. pipe then 10m 25mm dia. pipe and last 5m,20mm dia. pipe.
expecting the best
regards
Nitin K
Pipe size is irrelevant at no flow.
You need either static height from a tank or inlet pressure from the water main and then add or subtract as required.
Thanks for the answer ill check the parameters accordingly.
thanks you so much
Pressure when flowing will be different and depends on the flow into other basins at the same time from the same pipe.
