brutus1955
- Aug 19, 2003
- 57
figured i would try you guys on this one
i am working on a prototype alterntor, 500hz
57.6vdc at 75-100amps
i have a yokogawa analog dc amp meter (50mv) with its
500amp shunt, so i can read up to 500amps with decent resolution.
it has worked well with other alternators, but not this one
it reads about half of what it should at best if at all
usually it just sits there reading zero
if i move the shunt from between the battery bank and alternator to between the batteries and the load it works fine
so i put my oscope on the shunt and i have a bunch of AC noise on the DC line, evidently the diodes in this thing
are less than clean in operation.
so the question, how do i clean this up sufficiently so that my shunt/meter will read when inserted between the alternator and battery?
it has been suggested to place a capacitor of 10uf
across the shunt along with a .01uuf to filter out the noise
does this sound appropriate? can i have too much capacitance
and get a false high reading?
how does one get around this problem without doing something
different in the alternator?
looking for ideas here
thanks
bob g
thanks
bob g
