DC-DC converter- Input:160-320 VDC/ Output:300 VDC
Thmiko
I am looking for a DC-DC converter, any idea who could supply in South Africa?
POWER SUPPLY: TYPE: DC-DC; INPUT: 160-320 VDC; OUTPUT VOLTAGE:
300 VDC; OUTPUT CURRENT: 0.5 A; SPECIFICATION: T5081-01A; PART
NO: 3HB027140R0001;
Most OEMs would be able to direct you to the nearest distributor.
I've tried looking up your PN and spec, but can't find the OEM.
What's the OEM?
How is the DC voltage typically increased for his application? I can see a decrease in DC volts, if you're willing to lose the difference as heat. But how do you increase the volts from a steady DC current?
Buck-boost converter. It's easier to help if he says who actually made it; that information should be on the same plate as the part number.
That will be a very hard thing to find. A buck-boost on that voltage plane.. 150W.
Lots of AC-DC supplies will take DC in, in the 300V region without issue, but very few will put out 300V.
Keith Cress
kcress -
Vicor and Power One / Melcher used to be the go-to companies for Dc/Dc conversion.
Google search brought me to this russian excel spreadsheet
Row 4647 contains this data:
DMDR ACS6000 3BHB027140R0003 DC/DC CONVERTER T5081-01A 220VDC/300VDC 4B MVAC Drives Parts 4T ABB.PARTS.FISER3BHB027140R0003 6500.664 416042.496
The part number is slightly different, it has an extra B and ends in a 3 instead of a 1. It appears to be part of an ABB ACS6000 Medium Voltage Drive.
Like CarelO said, I would contact ABB.
