I know that on a composite feature control frame, the feature relating (second row) tolerance must have the same datum precedence as the pattern locating (first row) tolerance. Is this the case also for two separate single segment controls applied to a feature?
e.g., could I have an FCF locating a hole to A, B and C, and then a separate FCF under it locating the hole tighter to C only? Does it matter which one is on top and which is on the bottom?
