4
400Magnum
Guest
Hi all,
I have been trying to edit a datum point array in Pro/E and I have been running into a few problems.
First of all, there are about 200+ lines of datum points, each line consisting of an x and y coordinate. There is a datum point table that already exists for this model. The intent was to simply replace the existing datum points with the new datum points. In the past it's always been a simple matter of cut and paste. However, now there seems to be a limit to the number of points that can be put into the table at one time, and from that point on, you can only add a line at a time for a few numbers, and from that point on, you have to enter the datum point coordinates one entry at a time.
The limit for the initial placement of datum points seems to be right around 80 lines. Then you can go another 5 or 10 lines putting in one line at a time. After that, it's one coordinate at a time, and when you have to add another 100+ entries of datum point coordinates, it takes a long time, not to mention is pretty monotonous.
These are the steps I take. I pick the datum point array, select Redefine, and then Done on the first window, and then Edit Points at the second window, the PNT ARR TBL. The editor window opens with the existing datum points displayed. The new datum points are already created in an Excel spreadsheet and then selected and copied in the spreadsheet. Back in the editor, the cursor is located just before the existing points, I select Paste and the new points are inserted. I then select the previously used points and select Delete, and then select Save and then exit the editor.
We are using Pro/E 2001.
Is anyone else having this problem? Am I forgetting to do something or doing something wrong? Any help would be greatly appreciated.
Thanks in advance.
400Magnum
Thanks in advance.
400Magnum
