Data Exchange Dialog Boxes
robinbailey
GB
I have installed Autocad Data Exchange 2000 in Acad 2000 and it appears to run ok, but I cannot get the options dialog boxes to appear. I ahve tried entering a ~ at the promt but only get basic dialog box with no options tab. I need to change the default units to mm.
try an _ in front of the command normally that works if your not getting your dialogs check your filedia and cmddia settings they should all be set to 1
