The silicon used as a deoxidizer in many filler metals tend to leave deposits of silicon oxide on the surface of welds, but they are glass-like deposits that "shatter" when scraped or tapped with a welder's slag pick. I would tap a couple of the blackened areas to see if the deposits "shatter" in which case, it is likely the silicon oxides I've mentioned.
I suspect simple oxidation from insufficient shielding would be more consistent over the entire surface of the weld. Stainless filler metals can contain increased amounts of silicon (ER308Si, ER316Si for example)) that can produce more silicon oxide on the surface of the weld if a CO2 base shielding gas is used. The silicon acts as a deoxidizer, but it also changes the fluidity of the weld pool and helps reduce the amount of undercut along the toes of the weld.
The attached photograph depicts some porosity, but it also depicts some of the silicon islands I mentioned. Granted, the base metal is carbon steel, but the silicon islands can appear on stainless welds as well. Once the islands are chipped and removed, there is a slight difference in color under the silicon oxide islands.
Best regards - Al
