Hi all,
My company uses Inconel 625 parts in a water spray nozzle. The nozzle sprays fresh water at around 80-90degC and 50-90psi. pH is pretty neutral. The suspended solids content of the water is less than 5mg/l and dissolved iron is less than 0.5mg/l.
Our problem is that we have had returned nozzle parts from customers with damage after less than 1 year. The part is a small disc, roughly 12mm diameter, with a 3.5mm diameter hole in the centre through which the water flows. There is evidence of corrosion/erosion on the inner hole edge, and a brown tarnish on the material. The tarnished area is still smooth and hard, no flaking or pitting.
I'm very surprised that we see tarnish and damage on Inco625 from spraying fresh water at pretty low temps and pressures. Anyone any ideas as to possible causes?
Thanks,
FP
Thanks,
FP
