The basic question in this thread is a fundamental and practical one that has everything to do with (& about) Thermodynamic Phase Equilbria and very little or nothing to do with Dalton’s Law. This is a let down for me because John Dalton and his famous Law have always been favorite discussion pieces with me. John Dalton’s famous relationship is centered on gases and their vapor-state composition. What is being asked here regards the liquefied state of gases – Phase Equilibria.
This is all about basic Thermodynamics and this thread is certainly in the right Forum. I’m eagerly looking forward to what the real experts can contribute and throw in here with regards to this very fundamental and important Thermo subject. However, one should be warned: we’re going to have to talk about the Critical Properties of Pressure and Temperature as well as Bubble Points and Dew Points in order to truly address the basic question. To do that, we also have to say something about Equilibrium Constants.
In order to leave the door open for all who want to (or can) contribute valued comments, I’ll basically answer with the statement that all gases can be liquefied. However, when a mixture of gases is dealt with, the amount of condensation depends on the equilibrium constant and conditions under which the gaseous mixture finds itself. If a mixture is in equilibrium at a temperature between its bubble point and dew point, then by basic Thermo definition it must consist of two phases – liquid and gaseous. It is by making a Dew Point calculation (at a given pressure) that we can identify the temperature at which we will find the first formation of liquid. The manual reiterative calculations are a little tedious; a simulation program makes a quick resolution of the problem.
Depending on the amount of CO2 in the binary mixture, it is possible to have some of it liquefy – although I doubt this will occur at 2,200 psig with a nominal CO2 content less than 10%. What waross is stating is far-fetched and has little or nothing to do with the basic question. The amount of CO2 hasn’t been identified, so one can’t state if it would drop out of the gaseous phase by liquefaction. Scuba cylinders are indeed filled with high pressure air but the amount of CO2 in air is miniscule. However, I can easily prove that the partial condensation of the components of air is being carried out every day inside an air separation column. I did this for many years, producing both gaseous and liquid Oxygen and Nitrogen – from atmospheric air.
