I have been searching for tooling setup to skim cylinder heads on a mill. I have been told that you turn the head of the mill 1/2 deg to prevent backcut on the surface & use a large radius cutter with only a single cutting tool. But this would leave the decking surface slightly curved. Is this the correct method?
Does anyone have any pointers
The application is on small aluminium in line 4cyl motorcycle heads.
Thanks,
Michael
Thanks,
Michael
