I just found out about the CYSYMGEN param from Google. Prior to 8.4 I was wondering how this was done via FEMAP as setting up in the preprocessor would allow running the model in other codes.
Garland, the model has torsion applied to it so ordinary symmetry conditions would not represent the behavior of the problem correctly. Cyclic symmetry makes the nodes on the symmetry planes move together in the appropriate degrees of freedom.
