gte447f
- Dec 1, 2008
- 818
I have a project where a small hole or two (maybe 24"x24") need to be cut in a concrete slab. This is a one way concrete joist floor (pan joists) from the 1920's. I know these types of slabs are usually quite thin (maybe 2.5") and minimally reinforced with #3 bars because the spans are so short (usually only a couple of feet between joists). Provided that the holes can be positioned between joist webs so as to avoid cutting a joist, what issues need to be checked for the holes in the slab? Do the slab edges around the holes need to be reinforced? Will disrupting the continuity of the slab reduce the capacity of adjacent slab spans. Is it necessary to map the slab rebar prior to cutting to try to avoid cutting rebar? Thanks for any advice.
