HarpreetJagdey
- Apr 17, 2020
- 8
Hello all
I am working on this steel skid where I have to make access for the drainage pipes.
The bottom flange of UC254 has to be notched for a length of 150mm and depth of 95mm.
The beam span is 7.2m with intermediate transverse beams and the notch is in the centre of beam where moment is the maximum.
To withstand the design moment, the section has to be strengthened. I am looking to add two equal angles at the web for a length of 700mm, bolted to the web of existing beam via M16 bolts at 50mm staggered spacing. I need to design the bolts so as to make it act an integral section.
How do I calculate the bolt force required (longitudinal/composite action shear force)
Refer to attachment please.
