canwesteng
- May 12, 2014
- 1,711
For constructability, I would like to chop a column in half, move a large piece of equipment into the building, and splice the column back together. Surely this has been done before, but the one problem I can't get my head around is that the column will be a little shorter due to material removed when cutting it. Should the contractor be able to make a clean cut such that this is minimal or is this a legit concern?
