custom balloon shapes 1
Dtown266
Nuclear
Oct 31, 2006
47
Is it possible to customise the balloon shapes in solidworks
or to create custom shapes?
You could make blocks and use them as balloons. Do you need them for BOM callouts?
Go to Tools > Options > Document Properties > Detailing/Balloons and select from the options listed.
[cheers]
tick
Yes i need to use them for BOM Callouts. Can I do this with blocks?
i need to create a spit balloon that is "squircle" (hope you understand the terminology)
I'm not having any luck getting a block text or attribute to take on BOM item#.
I believe the nearest you will get is to select None for the balloon style (which will create a leader and Item # ... like a note) and then position a block around that.
I don't know of a way to add more balloon shapes to the existing ones. Submit an ER if it is that important to your company.
[cheers]
If you add a balloon without a border and then double click it and type in <SC#-1> this will add your squircle. This will also show up in a SW BOM and be linked. The only problem is that it doesn't auto update. Perhaps someone can improve on this.
felix7502 ... Interesting! Where did you learn that little snippet from? Are there others?
[cheers]
I changed the balloon to text, double clicked, and added a symbol from the text format box. All the symbols contained there have their own designation and you can create addition ones. I believe I contributed to a FAQ by CorBlimeyLimey to this effect.
Sylvia
Ahh, I see. It's just a symbol not a balloon.
Yes, you had contributed to faq559-1229 but not the Square-Circle one. I had forgotten those symbols were already listed in the Add Symbol option.
[cheers]
Symbol library coding ....... hes calling for included square-circle flag symbol #2 out of the symbol library.
Its similar to typing in <MOD-DIA> to get the diameter symbol out of the modifying symbol library.
Addt'l examples.....
<SC#P-5> will get the 5. square-circle symbol
<SCL-G> results in the G square-circle symbol
similarly ..
<T#P-3> calls for the triangle flag with the included 3.
After adding any symbol to an annotation, right-click it and choose 'Edit text in window' to see the coding.
Remember...
[navy]"If you don't use your head,[/navy] [idea]
[navy]your going to have to use your feet."[/navy]
Wow - did I have that window open for a while ....
Remember...
CorBlimeyLimey-
It is a symbol, but it will also be linked to the Item No. in a SW Bom. I tried with an Excel Bom and it appears, but then is hidden. Maybe a little equation would make it show up? or update?
Sylvia
It shows in a SW BOM Table also. Basically it is just overiding the BOM Item cell with an annotation.
[cheers]
