Curves Worthington Pump D-820 at 5,5 Hp
Yes I tried!
But in Flowserve there isn`t this pump because is an old model.
Take the pump info including make, model, serial number, impeller cut (dia.), rated head, and rated flow Flowserve. The picture of the nameplate you posted might even suffice. Ask them for a curve. It's worth a shot even if they no longer produce that pump.
Suggest you try a few companies who resell and supply pump to customers,
