Curve fitting using UF_MODL_create_fitted_spline with end slopes
WilsonBlr
Aerospace
IN
I am trying to fit a curve using UF_MODL_create_fitted_spline providing end slopes. One end of the created spline shows a loop back due to the slope constraint. I have observed that NX decides the direction of the slope vector automatically. I tried negating the slope vector but still it causes a loop back. What causes this loop-back and what is the workaround for this?
I have 7 points for fitting with order 3. For a higher order 6, I see the loop-back getting reduced but the curve seems to be over constrained.
Data points -
P1: -1.560260,-0.181989,3.286604
P2: -1.578313,-0.213621,3.273950
P3: -1.595170,-0.242289,3.264351
P4: -1.596874,-0.276042,3.260926
P5: -1.572996,-0.298280,3.269681
P6: -1.542036,-0.306016,3.282902
P7: -1.509833,-0.310289,3.298223
Slopes -
Slope at beginning: 0.762061,0.552460,0.337714
Slope at end: 0.911118,0.097702,0.400398
 http://files.engineering.com/getfile.aspx?folder=76362c7e-d02e-4d83-b7d9-73b4fafbe041&file=loopback.png
What version of NX, and can you post a code snippet that creates the spline for the data points listed above?
www.nxjournaling.com
Used NX 8.5 for this.
Code:
// standard headers
#include <iostream>
#include <fstream>
#include <string>
#include <sstream>
#include <time.h>
#include <stdio.h>
#include <uf.h>
#include <uf_ui.h>
#include <uf_exit.h>
#include <uf_defs.h>
#include <uf_modl_curves.h>
#include <uf_curve.h>
#include <uf.h>
#include <uf_csys.h>
#include <uf_part.h>
#include <uf_eval.h>
#include <uf_forgeo.h>
#include <uf_point.h>
#include <uf_modl_utilities.h>
#include <uf_modl_freeform.h>
#include <uf_modl.h>
#include <uf_evalsf.h>
#include <uf_modl_types.h>
using namespace std;
int ReportError( char *file, int line, char *call, int irc)
	if (irc)
		char err[133];
		char msg[256];
		sprintf_s(msg, "ERROR code %d at line %d in %s:\n",
			irc, line, file);
		UF_get_fail_message(irc, err);
		sprintf_s(msg, "Error Message: %s\n",err);
		//std::string filstr(file);
		//stringstream ss;
		//ss << line;
		//string str_line = ss.str();
		//sprintf_s(msg, "File : %s ... Line: %s\n",filstr, str_line);
		// create exception
		exception *ex = new exception(msg);
		throw ex;
	return(irc);
#ifndef UF_CALL
#define UF_CALL(X) (ReportError( __FILE__, __LINE__, #X, (X)))
#endif
int main(int argc, char* argv[])
	try {
		// Initialize NX
		UF_CALL(UF_initialize());
		// ----- This code is for constructing part name string  -----
		// create a temporary part name
		time_t now = time(0);
		tm *ltm = localtime(&now);
		char l_cTimeStr[256];
		// write to string
		sprintf_s(l_cTimeStr,"_%d%02d%02d_%02d%02d%02d",1900 + ltm->tm_year,1 + ltm->tm_mon,ltm->tm_mday, ltm->tm_hour, ltm->tm_min, ltm->tm_sec);
		// append to file name
		string partName = "BankFile";
		int index = partName.find_last_of('.');
		if (index>1)
			partName = partName.substr(0,partName.size()-index+1);
		int index1 = partName.find_last_of('\\');
		int index2 = partName.find_last_of('/');
		if (index1>index2)
			partName = partName.substr(index1+1,partName.size()-index1);
		else
			partName = partName.substr(index2+1,partName.size()-index2);
		// append the time stamp
		partName.append(l_cTimeStr);
		// Part tag
		tag_t m_tPartTagID;
		// Create part
		UF_CALL(UF_PART_new(partName.c_str(),2,&m_tPartTagID));
		// Spline Curve Structure
		SPLINE_FIT_t tFitSplineData;
		double	dMaxErr					=	0.0;			// Maximum err value
		double	dTolerance				=	0.001;			// Default Tolerance value
		tag_t	l_tSplineCrv			=	NULL_TAG;		// Tag of the geometry
		bool bIsFeature				    =	false;
		// Weight Data for the fit spline
		tFitSplineData.weights			= 	NULL;
		tFitSplineData.num_of_weights	=	0;
		tFitSplineData.weight_positions =	NULL;
		// Segments Data
		tFitSplineData.num_of_segments	=	0;
		// Tolerance always 0.0001 for all Airfoil curves
		tFitSplineData.tolerance		=	0.001;
		// Degree of the fit spline
		tFitSplineData.degree			=	3;
		// Point Data with its memory allocation
		tFitSplineData.num_of_points	=	7;
		// error code
		int nErrorCode=0;
		// allocate memory
		tFitSplineData.points			=	(double*) malloc(3*(7)*sizeof(double));
		// copy data to UF Array
		//P1: -1.560260,-0.181989,3.286604
		//P2: -1.578313,-0.213621,3.273950
		//P3: -1.595170,-0.242289,3.264351
		//P4: -1.596874,-0.276042,3.260926
		//P5: -1.572996,-0.298280,3.269681
		//P6: -1.542036,-0.306016,3.282902
		//P7: -1.509833,-0.310289,3.298223
		int nPt = 0;
		tFitSplineData.points[nPt] = -1.560260; nPt++; //1
		tFitSplineData.points[nPt] = -0.181989; nPt++;
		tFitSplineData.points[nPt] = 3.286604; nPt++;
		tFitSplineData.points[nPt] = -1.578313; nPt++; //2
		tFitSplineData.points[nPt] = -0.213621; nPt++;
		tFitSplineData.points[nPt] = 3.273950; nPt++;
		tFitSplineData.points[nPt] = -1.595170; nPt++; //3
		tFitSplineData.points[nPt] = -0.242289; nPt++;
		tFitSplineData.points[nPt] = 3.264351; nPt++;
		tFitSplineData.points[nPt] = -1.596874; nPt++; //4
		tFitSplineData.points[nPt] = -0.276042; nPt++;
		tFitSplineData.points[nPt] = 3.260926; nPt++;
		// P5: -1.572996,-0.298280,3.269681
		tFitSplineData.points[nPt] = -1.572996; nPt++;//5
		tFitSplineData.points[nPt] = -0.298280; nPt++;
		tFitSplineData.points[nPt] = 3.269681; nPt++;
		tFitSplineData.points[nPt] = -1.542036; nPt++;//6
		tFitSplineData.points[nPt] = -0.306016; nPt++;
		tFitSplineData.points[nPt] = 3.282902; nPt++;
		tFitSplineData.points[nPt] = -1.509833; nPt++;//7
		tFitSplineData.points[nPt] = -0.310289; nPt++;
		tFitSplineData.points[nPt] = 3.298223; nPt++;
		// slope definition
		tFitSplineData.slope_flag		=	3;		//
		tFitSplineData.slopes			= 	NULL;
		tFitSplineData.slopes =	(double*) malloc(6*sizeof(double));
		tFitSplineData.slopes[0]=0.762061;
		tFitSplineData.slopes[1]=0.552460;
		tFitSplineData.slopes[2]=0.337714;
		tFitSplineData.slopes[3]=0.911118;
		tFitSplineData.slopes[4]=0.097702;
		tFitSplineData.slopes[5]=0.400398;
		// Create Fit Spline with the above structure filled
		UF_CALL(UF_MODL_create_fitted_spline(&tFitSplineData, &dMaxErr, &nErrorCode, &l_tSplineCrv));
		// Save part
		UF_CALL(UF_PART_save());
		// close part
		UF_CALL(UF_PART_close(m_tPartTagID,1,1));
		UF_CALL(UF_terminate());
	catch(exception e)
		cout<<"An error occured. Please see the file ErrorLog.txt to see details."<<endl;
		cout<<e.what()<<endl;
		FILE* fptr;
		fptr = fopen("ErrorLog.txt","w");
		fprintf(fptr,"\n\n");
		fprintf(fptr,"An error occured\n");
		fprintf(fptr,e.what());
		fclose(fptr);
	catch(exception *e)
		cout<<"An error occured. Please see the file ErrorLog.txt to see details "<<endl;
		cout<<e->what()<<endl;
		FILE* fptr;
		fprintf(fptr,"An error occured running MeshIC application\n");
		fprintf(fptr,e->what());
		fclose(fptr);
Can I suggest you set the tolerance to a larger value say 0.01. The output the maximum error and the point at which the maximum error occurs.
I ran your data with no slope control then the maximum error was 0.008 at point 4 (point numbers 1 to 7)
I then ran it using your end slopes and the maximum error was 0.0098 at point 2
Now the problem is that if you need to get a tighter tolerance and you increase say the order or the number of segments then the spline does the looping that you indicated.
Hope this helps
Frank Swinkels
