I have CT & PT designed for 60Hz system and tested per ANSI/IEEE standards but those will be used on 50Hz power system.
If so, are there any advices on this issues? I guess CT & PT burden should be derated accordingly and CT saturation will be faster than the same CT in 60Hz. Did I correctly understand?
If those 60Hz CT & PTs are used for protection system on 50Hz power supply, any advices on protection settings?
Thanks in advance for your advices.
