The clause 13.13.4.3 (a) in S16-19 states. If you are confident of the loads and you want to design the HSS weld for the actual forces in the weld you must design the weld for a minimum 50% yield of the connected wall. This clause seems very vauge? Does it apply only in HSS to HSS branch connections due to the unknown stress distribution in the joint. If there was a HSS to a Cap or base plate with a moment would it apply in that situation also? The commentary does not really help much either.
