msquared48
- Aug 7, 2007
- 14,745
cross grain bending
thread337-246096
I posted to in 09 that I never got beyond my first post. A little late, but here goes...
Cross grain bending was mentioned in the '79 UBC in section 2312(j)3A and states that it should not be used, specifically for concrete to wood connections in a seismic area.
It is also referred to in ASCE 7-05 in section 12.1.2.2.3 and also placed in the seismic section as a nono.
That being said, I could find no reference to wind limitations in the code except for that implied in ASCE section 1.4, General Structural Integrity, where the direct reference to providing multiple load paths in the design is mentioned.
Therefore, considering the failure mechanism of cross grain bending, even for the wind application, the implication is to provide a second means of transfer of any lateral force to a ledger, or a sill plate for that matter, as it is just a ledger rotated 90 degrees. The force diagram is the same. Hencew the need for direct wall ties of a wood diaphragm to a tilt-up concrete wall, or the use of holddowns at the ends of shear walls instead of relying on the tension force in the anchor bolts against the sill plate,
Mike McCann
MMC Engineering
thread337-246096
Mike McCann
MMC Engineering
