Cross-Bracing Stiffness 1
dik
26,083
I'm modifying my spreadsheet for lateral load distributions and rather than use walls, I'm using cross-bracing. I'm looking for the stiffness of bracing for a movement in either the x or y direction.
I seem to recall it is of the form delta=P*x/(A*E*cos^2(alpha)
or
K=A*E*Cos^2/x
where A&E area and Young's modulus, x is the horizontal x-dimension, and alpha is the angle of the bracing to the horizontal. The squared value converts the P force to the diagonal force and the x dimension to the diagonal length. K is the stiffness. [post modified]
Can anyone confirm or provide a 'correct' formula?
Dik
This goody might get you where you need to go: Link
I'll take a gander... thanks
Dik
Great Post with the relative components of the diagonal, the column and the girder.
My rough recollection is for the diagonal component of it. I'll take a look to see how it varies for all components; I suspect the girder and the columns will be minor.
Again, thanks very much.
Dik
