dik
- Apr 13, 2001
- 26,083
I'm modifying my spreadsheet for lateral load distributions and rather than use walls, I'm using cross-bracing. I'm looking for the stiffness of bracing for a movement in either the x or y direction.
I seem to recall it is of the form delta=P*x/(A*E*cos^2(alpha)
or
K=A*E*Cos^2/x
where A&E area and Young's modulus, x is the horizontal x-dimension, and alpha is the angle of the bracing to the horizontal. The squared value converts the P force to the diagonal force and the x dimension to the diagonal length. K is the stiffness. [post modified]
Can anyone confirm or provide a 'correct' formula?
Dik
or
K=A*E*Cos^2/x
Dik
