Creating and Assigning Material
SteveVan
16
Is there a way to assign a material to a part from a list.
Example: If I assign Steel to a part, I want it to ask what kind of steel: bar stock, flat Stock, or Sheet.
If I select bar stock I want to select from a list the available material types of bar stock we have in stock
(CF 1018). After I select (CF 1018) I want to select from a list the available diameters of the bar stock. I also want the assigned material to automatically fill out the parameter setting used in the drawing.
Thanks for any help
I don't think that can be done without a custom developed application (i.e. Pro/Toolkit).
If you're feeling adventurous, take a look at Pro/Web.Link. It has commands for accessing and modifying parameters through Javascript written in a webpage (loaded up in the Pro/E browser).
you might want to wait for wf4...vba
I'm seeing a demo monday
or VB if you have it...be pretty easy
but external app. and you need 6 or .net
jkg,
it was from a vendor. It's seems to be closer to vb than vba .
They didn't get into much detail, but looks promising
Thanks for the replies. Just to let you guy's know I had 3 replies from the forum in the time it took Pro-e tech line to call me back. They said it might be possible with Pro tool kit but he wasn't sure. Thanks again for the fast response.
"They said it might be possible with Pro tool kit but he wasn't sure"...
That's one of the reasons my employers choose not to pay maintenance...
ProToolkit can do this. Assigning the material to a part is quite easy, but creating the database can take you some time.
-Hora
Steve,
if you chain a os mapkey in with another normal proe mapkey
ex;.... mapkey ed %wd;%tr;
and wd is a bat or exe.... proe waits till it's done to resume the mapkey tr
so you could use anything that compiles to a exe, gives you the ability to make choices and can write that to a .txt file ...vb,net,c,vbs..etc.
