This might be easier to look at. Same data as above, but I took the heading and put it in capital letters with colon
) to the left of each entry. The seaparated the rows with carriage returns. Sorry to make somethign so simple be so complex.
INPUT DESCRIPTION: Nut factor UNITS: None SYMBOL: K EXAMPLE VALUE: 0.20 FORMULA: INPUT (Note 1)
INPUT DESCRIPTION: Diameter inches UNITS: inches SYMBOL: D EXAMPLE VALUE: 0.75 FORMULA: INPUT
INPUT DESCRIPTION: fractionM of yield UNITS: None SYMBOL: M EXAMPLE VALUE: 0.50 FORMULA: INPUT
INPUT DESCRIPTION: Stress - Yield psi UNITS: psi SYMBOL: Sy EXAMPLE VALUE: 95000.00 FORMULA: INPUT
INPUT DESCRIPTION: Threads per inch UNITS: TPI SYMBOL: TPI EXAMPLE VALUE: 11.00 FORMULA: INPUT
CALC DESCRIPTION: Thread tensile area UNITS: inch^2 SYMBOL: As EXAMPLE VALUE: 0.34 FORMULA: =0.7854*(D-0.9743/TPI)^2
CALC DESCRIPTION: Target stress UNITS: psi SYMBOL: Starget EXAMPLE VALUE: 47500.00 FORMULA: =+Sy*M
CALC DESCRIPTION: Fpreload UNITS: lbf SYMBOL: Fpreload EXAMPLE VALUE: 16321.07 FORMULA: =+Starget*As
CALC DESCRIPTION: T (inch-lbf) UNITS: inch-lbf SYMBOL: Tinchlbf EXAMPLE VALUE: 2448.16 FORMULA: =+K*D*Fpreload
CALC DESCRIPTION: T (ft-lbf) UNITS: ft-lbf SYMBOL: Tftlbf EXAMPLE VALUE: 204.01 FORMULA: =+Tinchlbf/12
