There should be a road property file called mdi_2d_flat.rdf lurking somewhere, which is enough to get you going.
Here it is in all its glory
$---------------------------------------------------------------------MDI_HEADER
[MDI_HEADER]
FILE_TYPE = 'rdf'
FILE_VERSION = 5.00
FILE_FORMAT = 'ASCII'
(COMMENTS)
{comment_string)
'flad 2d contact road for testing purposes'
$--------------------------------------------------------------------------UNITS
[UNITS]
LENGTH = 'mm'
FORCE = 'newton'
ANGLE = 'radians'
MASS = 'kg'
TIME = 'sec'
$--------------------------------------------------------------------------MODEL
[MODEL]
METHOD = '2D'
ROAD_TYPE = 'flat'
$-----------------------------------------------------------------------GRAPHICS
[GRAPHICS]
LENGTH = 160000.0
WIDTH = 80000.0
NUM_LENGTH_GRIDS = 16
NUM_WIDTH_GRIDS = 8
LENGTH_SHIFT = 10000.0
WIDTH_SHIFT = 0.0
$---------------------------------------------------------------------PARAMETERS
[PARAMETERS]
OFFSET = 0.0
MU = 1.0
Tire data is a lot harder to get, have a look for C:\Program Files\MSC.Software\Adams\2019_2_2\atire\tires.tbl\pac2002_175_70R13.tir where you may need to change the install directory. That's a Pacejka model so you can modify the coefficients to fit your tire.
If you don't have adams/tire, car or chassis then things start to look a bit awkward. If you want to get into generating your own tir files then
is a good place to start.
Failing that random googling leads to various websites that have demo tires.
Cheers
Greg Locock
