Create a jogged extension line not dimjogline 1
frankreid
Need to create a dimension that is shown but the extension lines are on another line, not precisely what I want. I need the command that will let me point the extension line to the right place then "jog over" a little to get it off the other line. Clear as mud? Need some help here.
Frank Reid
Reid Engineering Services of Utah
Not quit clear. Right click and then left click on the dimension --> "Dim Text position" --> "Move with Dim line" and then move it, provided that's what you mean.
Sorry, made a mistake - first left and then right.
Left click the dimension then use the grips to move the text?
Use DimBreak to break the dimension line?
Hard to know what you need...
I didn't make myself clear. Maybe this attachment will show what I want. When the extension lines are close to another object but I want to move them away from it I would use a "jog" in the lines. Maybe I'm using the wrong word. Here is what I meant.
Frank Reid
 http://files.engineering.com/getfile.aspx?folder=3875babb-36bb-4000-935b-a0fe83779e81&file=DIMENSION_EXAMPLE.dwg
Nothing in AutoCAD for this. But, what I do is leave the dimension associative, turn off the extension lines and draw my own polylines for the jogged extension lines.
