I have some critical service pivot pins in a heavily loaded piece of plant equipment for which I am having spare pins manufactured.
My original equipment supplier furnished details of the pins and associated parts at time of order placement several years ago. The drawings include the required material, heat treating specification, finish dimensions and plating.
One of the pins cracked during flame hardening, and the heat treater says the specification is at fault. The original equipment supplier says the specification is without fault.
I am looking for some informed opinions from experienced Metallurgists.
The specifications are as follows:
Material: AISI 4340, 12" diameter x 34" long (approx.)
Through harden to a mid-radius yield strength of 148,000 psi yield strength and flame harden to a surface hardness of 45-50 Rockwell C.
Finish diameter is 300mm j6 at 32 micro-inch average roughness after plating.
Plating is to be Nedox FM-5 by Magnaplate.
Constructive comments are requested and will be very welcome.
