Crack Propagation with ABAQUS DEBOND
yve
Materials
DE
i try to find out the posibilities using ABAQUS *DEBOND function to calculate crack propagation of a CT-Speciem.
I defined an amplitude for the load to simulate one loadcycle in a step (both same time)in the first step my Model debonds as expected (3 Nodes). And in the following it doesnt, i can see that the fracture criterion at the cracktip node (in defined distance tothe node)is fullfilled but nothing happens. It is an linear elastic calculation. It doesnt make a difference if i take one cycle per step or if i define more cycles in my *Amplitude and calculate them in one step. My Question now is: can I use the debond funktion with a cyclic load? I havent found anything in the manual like this.
Anybody an idea? my file is below. All nodes are in the BOND set, every second node is defined as a crack tip i used CPE8 Elements, as I am interested in stress gradients too, i took quadratic elements. I know linear elements are recomended but noone said quadratic elements doesnt work.
Yve
**Define Amplitude for Load Cycle 1-1-1-1 from 0 to 100%
*Amplitude, name=Cycle1-1-1-1
0., 0., 1., 900., 2., 900., 3., 0.
4., 0.
** MATERIALS
*Material, name="linear-elastic"
*Elastic
210000., 0.30
** CONTACT DEFINITION
** INTERACTION PROPERTIES
** Contact between LoadPin and Hole
*Surface Interaction, name=ContactPinHoleProperty
1.,
*Friction
0.,
*Surface Behavior,pressure-overclosure=HARD
*Contact Pair, interaction=ContactPinHoleProperty,small sliding, adjust=0.001, no thickness
CT-Speciem-2D-Shell-1.Surf-1, Pin-2Danalyticalrigid-1.Surf-1
**Contact Definition for Debonding Ligament
*Surface Interaction, name=LigamentPlusContact
1.,
*Contact Pair, interaction=LigamentPlusContact, small sliding
CT-Speciem-2D-Shell-1.Ligament, LigamentRigidSurface-1.RigidSurface_
** Initial Condition for Debond
*Initial Conditions, Type=Contact, Normal
CT-Speciem-2D-Shell-1.Ligament, LigamentRigidSurface-1.RigidSurface_, CT-Speciem-2D-Shell-1.BOND
**Berechnungsschritt
** STEP: Step-1
** STEP: Zyklus 1 Last 1-1-1-1
*Step, name="Zyklus 1 Last 1-1-1-1", Inc=400
Loadzykle 1-1-1-1 Max Load on Pin 900N/mm²
*Static
0.01, 4., 1e-09, 4.
** BOUNDARY CONDITIONS
** Name: LigamentRigidSurfaceFixdisplacement Type: Displacement/Rotation
*Boundary
RFnodeLigamentrigidsurf, 1, 1
RFnodeLigamentrigidsurf, 2, 2
RFnodeLigamentrigidsurf, 6, 6
** Pin-2Danalyticalrigid-RefPt_
** Name: Pin-2Danalyticalrigid-RefPt_ Type: Displacement/Rotation
*Boundary
RFnodePin, 1, 1
RFnodePin, 6, 6
** LOADS
** Name: cyclic load on RP of Pin Rigid Type: Concentrated force
*Cload, amplitude=Cycle1-1-1-1
RFnodePin, 2, 1.
**DEBOND OPTION
*Debond, Slave=CT-Speciem-2D-Shell-1.Ligament, Master=LigamentRigidSurface-1.RigidSurface_, Time Inc=1.E-07, Frequency=1,Output=BOTH
0.,1.
1.E-7,0.,
*Fracture Criterion, Type=Critical Stress, Tolerance=0.01, Distance=0.01
1300.,1.E12,1.E12
** OUTPUT REQUESTS
*Energy Print
*Contact Print,Master=LigamentRigidSurface-1.RigidSurface_
CSTRESS, CDISP
DBT,DBSF,DBS
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*Contour integral, crack name=H-Output-2_Crack-1, contours=10, symm, Output=BOTH
CT-Speciem-2D-Shell-1.CrackTip1, -1.,0.,
*Contour integral, crack name=H-Output-3_Crack-2, contours=10, symm, Output=BOTH
CT-Speciem-2D-Shell-1.CrackTip2, -1.,0.,
*Contour integral, crack name=H-Output-4_Crack-3, contours=10, symm, Output=BOTH
CT-Speciem-2D-Shell-1.CrackTip3, -1.,0.,
*Contour integral, crack name=H-Output-5_Crack-4, contours=10, symm, Output=BOTH
CT-Speciem-2D-Shell-1.CrackTip4, -1.,0.,
** FIELD OUTPUT: F-Output-1
*Output, field
*Contact Output, VARIABLE=ALL
CSTRESS, CDISP
DBT,DBSF,DBS
*Output, field
*Element Output,Elset=CT-Speciem-2D-Shell-1.ALL
S,E
*Node Output, Nset=CT-Speciem-2D-Shell-1.ALL
U
*End Step
You can try.
Regarding :
"It doesnt make a difference if i take one cycle per step or if i define more cycles in my *Amplitude and calculate them in one step."
It can make a difference if you use automatic time incrementation and you have sudden changes in cyclic load profile.
If I have kinks in the cyclic load profile (non-smooth loading cycle), I decompose the cyclic load in several subsequent steps. Thus, I know exactly the value of the applied load at the kink in the loading cycle since ABAQUS will perform a computation at the end of the step.
Also, in this way I can make the analysis more efficient when some portions of the loading cycle lead to a more non-linear response of the structure (e.g. crack faces come in contact, plasticity etc.) which require smaller time increments.
Thank you xerf, ill try this.
