CPSET in CLEARENCE command
jcfhh
14
Hi all,
I am trying to do the simulation of lying a 3D tire model lying on the road horizontally and adding load on its sidewall to see its deformation. However I think there is a contact problem in my simulation. When I run the analysis, the analysis did not complete and it showed an error is the msg file. The error is "TOO MANY ATTEMPTS MADE FOR THIS INCREMENT". It also showed a warning as " CONTACT PAIR (SIDEWALL-DOWN,SROAD_2) NODE 97752 IS OVERCLOSED BY 9.04135 WHICH IS TOO SEVERE."
I did some research in documentation, I found that the following two statement may help to solve the error, therefore I hope someone can help me to have a look if these commands can solve my problem:
the first one:
*CLEARANCE, CPSET=cpset_name, TABULAR, However, for this command, I do not know what I should type for cpset_name and
for the second one Ido not know what I should type in amplitude since there is no amplitude in my current input file:
*CONTACT PAIR, ADJUST=a
slave_surface, master_surface
*AMPLITUDE, NAME=amplitude_name
*CONTACT INTERFERENCE, AMPLITUDE=amplitude_name
slave_surface, master_surface,v
Could anyone please tell me how to solve my problems?
Thank you very much.
Best Regards,
JC
The meaning of these keywords and parameters is explained in the Keyword Reference Manual and the Users Manual.
