I had a french drain put in the basement. The installer left a space on the floor of an inch or two around the perimeter of the basement. I now need a oil tank installed and they want to cement the fuel line so it won't get accidently disturbed. They said they can cover up the space left by the french drain installer where the cement on the floor will now meet the wall with no open gap. Is this ok or does it invalidate the french drain? I am assuming the gap is there for a reason, but the oil company insists it can be closed up and it will not impact the functioning of the drain.
