Recently, our refinery have experienced higher steam consuming when it rains and ,we think, one possible reason will be performance loss of steam trap by higher heat loss on the surface(most of our traps are thermodynamic type). In other words, vapor pressure on top of the trap disk will be condensed by cold rain and it will not trap condensate properly. Finally steam loss. Above is the logic we thought, so now we are considering covering of steam trap. Re this matter please comment on following question if you have good explanation.
a) Does the covering of steam trap(esp. thermodynamic
type) is common practice ?
b) If it is common pactice, how do you usually covering
steam trap ?
c) If you cover steam trap, how do you usually evaluate
the performance of steam trap cover ?
d) Any other method, improve steam trap performance loss
when it rain ?
your comment would be highly appreciated.
steam trap ?
when it rain ?
