behindpropellers
New member
- Feb 23, 2005
- 73
I had a complaint yesterday that countersunk screws on some machines we build are hard to initially break loose. Some of these screws have loctite on the threads. I am not sure if loctite is also getting under the head. This only seems to be a problem after a few years.
I understand that once these screws are torqued the torque creates great friction between the countersunk head and the host material. I am sure there is some corrosion, but when we are using steel screws on steel parts I am ruling out dis-similar corrosion.
Is there any way of getting around this?
My initial thought is that this is not a problem, just the way it is. Will never seize under the heads help?
Tim
Tim
