Jan 25, 2022 #1 K kpinks Guest How would I model a countersunk 3/8-16 tapped hole on the side of a cylinder?
Feb 5, 2022 Thread starter #2 B BrandonKlar Guest You've probably figured out a method, but this is how I go about it if the C/S is dimensioned per your example
Feb 22, 2022 Thread starter #3 C Cadasio Guest Could you not use a custom hole wizard? Placing it using a 3D Sketch
