Countersink Bit on a shaft 1
saad.mech
PK
Hello there. I am implementing the GD&T standard (ISO) and wanted to know how would I dimension a part on the drawing that uses a countersink bit. The bit is to be used on a shaft where the cone of a M4 set screw will seat, there are no threads.
If you used the Hole wizard to make it then its easy to add a dimension in a drawing. If all you did was make a countersink using a revolve feature or something then you will probably need to section the drawing to add your dimensions to it. If it's supposed to be an M4 hole with a countersunk screw, then I would use the Hole wizard. Not all hole wizard holes have to have threads.
Scott Baugh, CSWP [pc2]
Mechanical Engineer
Ciholas
"If it's not broke, Don't fix it!"
faq731-376
Even without sectioning SW can insert centerlines for those hidden surfaces. Then dimension to the centerlines.
