Could someone help me with this callout problem
bmarchand
Automotive
CA
I can't figure out how to make the separator line only between the 1 and the 4 --not the entire callout
Has anyone else had this (file attached)
Thanks,
Brian Marchand-Die Designer
NX 9.0.2.5 / PDW
Dell Precision T7610 w/Xeon ES-2609
16G Ram - Nvidia Quadro K5000
Win 7 Pro x64
Yes, I could help you if I was at work
You need to expand your annotations menu all the way to find the fractions menu.
In the settings page?---can't seem to find the fractions bit
NX 9.0.2.5 / PDW
Win 7 Pro x64
maybe go into your command finder and enter "fraction annotation" and see what comes up
the command finder is the binoculars icon on your toolbar
I found the fraction area under the notes dialog, but that's not it---its not a note
It seems to be something with the hole callout dimensioning
If its a "thread feature", then it works fine, when its a "symbolic thread" then it gives me the line between the upper and lower---now in the case of 10-24 unc, it puts a line under the entire text, nothing underneath
If I go into settings and uncheck the callout so it puts nothing there, the stub portion of the leader is correct, if I turn on length only it puts the line back
Thanks,
NX 9.0.2.5 / PDW
Win 7 Pro x64
But when its a fraction style like 1/2 - 13 unc, it has the 1 on top by itself, a line under everything, then the 2-13 unc by itself, and a stub leader under everything
wierd
NX 9.0.2.5 / PDW
Win 7 Pro x64
Yes, the video should help you see what the new preferred method is for creating Hole Callouts in NX 9.0. While the old...
Insert -> Dimensions -> Feature Parameters...
...function still exists, the preferred approach is to now use the new 'Hole Callout' method option found on the Radial Dimension dialog.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
