I'm currently studying the influence of oxygen in different kinds of environment in oil and gas industry : in the case of an oxygen entry into "wet" gaseous phase flow, oil/water flow and in the case of process utilities (in particular the ones with fresh water involved).
Concerning fresh water systems, the data I am looking for are graph or formulas which could directly lead to calculation of the corrosion rate in function of dissolved oxygen content, temperature, oxygen partial pressure, total dissolved solids ... Does it exist ?
Then I've read about the effects of oxygen entry on corrosion mechanisms but I would like to have a value to "set" a limit of how much oxygen is allowable in the systems. That is a really general study but I need some particular values to have a reference.
At the moment data on carbon steel would be more than welcome, then if you have anything else about different materials, feel free to mention it.
Unfortunately I can not access the documents you mentioned but I keep on going.
Thank you for your answers, kind regards.
