Corrosion resistance of Brass
Redpoint
11
Does anyone know how yellow brass will hold up to phosphoric acid? I don't have that extensive of books which has that kind of information. Any help would be appreciated.
In general, the following materials, Al , cast iron, steel, brass and ferritic and martensitic stainless steel exhibit poor corrosion resistance in phosphoric acid.<br>
<br>
To be specific for 70-30 brass corrosion rate at 70 F 100% corrosive medium of phosphoric acid the corrosion rate is &gt; 0.05 mpy (mil per year) which is very poor and unacceptable in metallurgical sense.<br>
<br>
Type 316 austenitic Stainless steel will be a choice for phosphoric acid environment . It can be used up to 85%conc. and temperature up to boiling point with little attack.<br>
<br>
<br>
Regards,<br>
Surin Tan
