prc
- Aug 18, 2001
- 2,013
Corrosion is noticed in cooling water tube of a transformer cooler.It is a shell-tube heat exchanger with cooling water inside the tube.Tube is 90:10 cupro-nickel with water velocity of 0.45 metre per second.River water(not polluted) is used . Tube dia 16/14mm. After nearly 2-3 years of service localised corrosion finally result in pin hole formation in the tube.Some say it is crevice corrosion.Can any one throw some more light?What is the reason for this? How to prevent it?
