Correction for rubber membrane in CU triaxial test
ypyenpham
VN
Everyone can guide to correct for rubber membrane in CU triaxial test. The diameter specimen is 38mm, height to diameter ratio is 2. The thickness rubber membranes is 0.012''. I don't know to choose Young’s modulus suitable value.
Thanks,
YP
Use a condom and neglect it.
Ron - remember that MIT or Harvard (can't remember which) actually carried out tests on the "best" rubber membranes - back in the early 1970s? Trojans came in first!
BigH...I remember it as well. We used them for years. Higher quality and thinner than the "scientific" membranes.
Dave - don't tell me you reuse 'em!! Won't work so well with the end cut off!
Is that why I have 14 kids?
(Really only two.)
The lab techs always complain when they have to use the used ones!![lol]
Dave...I thought you would have figured it out after about #10.
If you're testing very soft or sensitive clays, it can be important.
From my graduate lab class:
Membrane resistance (N) = -pi*initial membrane diameter* thickness * 140 N/cm^2 * (axial strain +0.66*volumetric strain)
Volumetric strain is 0 for undrained shear
Hi, GeotechinTraining
Your formula is very good. But this is your experiential lab. Where is the formula refer? Book or paper names?
TY
You could check BS1377:Part 8, there is a short paragraphy about membrane correction.
