electricpete
I was looking at a group of motors that seem to be running much hotter than expected by comparison to factory data.
Then I realized that the factory calcs seemed way off base.
It's a 1250hp motor (4kv, 1190rpm).
They measured a temperature rise of 61.1C when running at 1003 horsepower.
Based on the above they estimated the temperature rise if the motor were running at full horsepower would be 69.4C. (I estimate way higher... what do you come up with?).
Here was their logic:
Losses=HP*0.746*(1-eff)/eff
They have "measured" efficiency values of 0.94 at 80% load (1000hp) and 0.945 at 100% load (1250hp)
Losses at 1003hp=HP*0.746*(1-eff)/eff=1003*0.746*(1-.94)/.94=47.76kw
Losses at 1250hp = HP*0.746*(1-eff)/eff= 1250*0.746*(1-.945)/.945=54.27kw.
Since temperature rise is proportional to losses:
rise(1250)=rise(1003)*losses(1250)/losses(1003)=61.1*54.27/47.76=69.42
The above is their calculation.
Here's the way I look at it (the way we did it when I worked on transformers)
TL=NLL+LL
TL= total losses
NLL = No load losses (constant with load)
LL = load losses (vary with approx square of load).
TL(1250)=TL(1003)*[alpha + (1-alpha)*(1250/1003)^2]
Rise(1250)=Rise(1003)*[alpha + (1-alpha)*(1250/1003)^2]
where alpha is the fraction of total losses which are no-load losses.
If alpha=0.2 => Rise = 88C
If alpha=0.4 => Rise = 81C
If alpha=0.6 => Rise = 75C
If alpha=0.75 => Rise = 69.5C
I have to get awfully high alpha to predict their result. Maybe there is a small problem with my definition of alpha as written.... it will be the fraction of NLL at 80%, not 100%. I'll see if that makes a difference.
In the meantime any comments?
TL=NLL+LL
TL= total losses
