I just got off the phone with my VAR and he told me some very interesting things regarding the Copy Settings Wizard (CSW). Since I have a bunch of relatively new users here I used the CSW to quickly setup everyone's machine the same. This was particularly useful for the setting file locations in addition to the toolbar settings. I also made a "home" version that was identical except that it was stripped of its references to network file locations. All we then had to do was setup a few standard directories on our hard drives, run the CSW, and all would be good with the world.
Apparently the CSW is not really the administrator's tool I'd like it to be. My VAR said that since we have different operating systems the CSW might not give us the complete results we would like. It writes to registry keys and these registry keys are different between operating systems. For instance, between our home and work computers we have four OS's: XP-Pro 32-bit and 64-bit, Vista Pro 64-bit and Windows 7 Pro? 64-bit.
We have used the work and home CSW's without an obvious problem, but we might not have everything the way we would like. Apparently the CSW is better suited as a backup tool for a given machine (OS) than as an administrator's tool.
I'd like to hear from those of you that have some insight into this situation. How do you administer the installations between users at work and further, how do you spread that to the home installations?
Thanks,
- - -Updraft
Thanks,
- - -Updraft
