edison123
- Oct 23, 2002
- 4,508
What is the normal temperature rise (Outlet water temp - inlet water temp)in air-to-water cooled machines ? I had always assumed it to be 2-3 deg C. But in one generator, it is around 6 deg C. Flow rate & pressure are normal as per name plate. Does this mean the coolers have insufficient capacity ?
* Basically, I would like a full-time job on part-time basis *
