A 30 year old existing condenser water loop system has a full 6" cooling tower bypass with control valve fairly close to the pump (below roof) as well as a small 1" bypass with steam-heat and auxilary pump closer to the tower end of the lines (still below roof). The installation is in Indiana. Intent of the equipment is to obviously have the ability to run the system during winter/shoulder months and I would like to start operating it this way. My concern is that I could still freeze up the pipes or basin when the tower bypass is activated since water will be circulating below roof in this mode and I would think that there will be stagnant water in the above-roof lines/sump. Is this a valid concern? at minimum shouldn't the piping be insulated to the tower? It seems like electric basin heater is more foolproof (Marley quoted 9kW and 12kW heaters) but I don't want to spend the money if it's not needed.
