Dear all,
I have a case where the cooling tower location is 15m lower than then PHE unit it is connected to. The issue is during the filling or when the pump power off, all the water at higher level area will flow back into the cooling tower.
Do I need to add check valve to prevent water flow back into the cooling tower basin or is there any other solutions?
thanks
thanks
