Vicsidhu
- May 3, 2001
- 35
I am designing an ice rink. There is a race track in a stadium (Oval) which is made of materials which has high U-values (blacked out good glass as walls). I have calculated the cooling load, which is quite high as expected. What I have not incorporated is the effect the chunk of ice on the ice track will have to the space. Obviously this will be a negative load to the space.
My question is: How can i determine the negative load this ice race track provides to the room? The referigeration plant is separate and my only concern is the cooling or heating in summer and winters respectiely.
So the parameters for this are:
Ice surface temp: -7°C
Space temp: 17°C
Ice race track Surface area: 5000m²
I need: Load for ice track in kW ot Btu/h
thnx!!
Space temp: 17°C
thnx!!
