Shockdesigner331
- May 13, 2005
- 69
I've got an insulated 2 Part ev chamber. One part of the chamber holds many blocks of dry ice, the other part holds the test specimen to be cooled. 2 insulated ducts with fans push and pull air through the chambers circulating the cold air.
After a day of circulating the cold air the AIR temperature flat lines at -45°F. I know dry ice is -100°F. What is the coldest temp that I can get the air to?
The EV chamber is quite well insulated. Outside of the chamber is not cold to the touch, no condensation visible, fans running with no problems. I need to get the air to a lower temp.
Any thoughts? thanks.
