Homework?
From any practical standpoint, this makes no sense at all.
And, you can't "maintain" mineral oil at -20 degrees C with dry ice because while dry ice is condensed out from gas into vapor at -78.2 C, but the actual received temperature of your ice could be anything less than -78.2 C. Dry ice is STORED at much lower temeprature than -78.2 C.
" from the web: At temperatures below 195 K (-78.2 °C, -108.7 °F) carbon dioxide condenses into a white solid called dry ice.
Keep in mind that it can become much colder once the solid is formed. Materials that are not changing phase do not have one set temperature as the question implies. "
Now, your mineral oil will cool very rapidly (too rapidly ?) but only in very limited areas of your container because dry ice immediately around the oil will be boiling away and splashing the oil around; but then the mineral oil will keep cooling down until it (possibly) reaches the received temperature of the dry ice. So your temperature "could" go much further down past -20 C. Or maybe not - see comments above
Regardless, your mineral oil won't "stop" cooling down until all the dry ice is gone. At that time, your oil will immediately begin warming up. Until you dump in more dry ice. Atw hich time it will begin rapidly cooling again. Rinse, wash, repeat indefinitely ?
